kenaslan
- Billings MT
Here is my situation.
A carbon steel above ground oil pipeline is connected to a stainless meter pipe, then back to a carbon steel pipe is understandably having internal galvanic corrosion issues. The mechanical guys want to put isolation flanges in and have no conductivity whatsoever. They believe that a bonding jumper will once again cause the galvanic corrosion, and want to completely isolate the SS meter pipe. This is in a C1D1 area.
My understanding is that a bonding jumper should be at the flanges to prevent arc-over at the flanges from a nearby lighting strike. I also believe, and please correct me if I am wrong, that the friction of oil passing through an electrically ungrounded/bonded pipe will slowly cause a static charge buildup in the pipe between the two dialectic isolation flanges like a capacitor. Also 250 states "The permanent joining of metallic parts to form an electrically conductive path that ensures electrical continuity and the capacity to conduct safely any current likely to be imposed.”
