moab88
- West Virginia
- Journeyman Electrician
I have 3 separate enclosures . The dual meter base , one 200A breaker disconnect on left side and another 200A breaker disconnect on right side. Each breaker serves as main disconnecting means for 2 separate panels. My N-G bond will occur at each disconnect where I will then run 4AWG bare copper wire to ground rods. Both initially connecting at the same ground Rod and one of them extending out connecting to second ground Rod. Should I run RMC nipple between dual meter base and each disconnect and bond it with bonding bushing or should I run PVC?
