bernardmulherin1978
- augusta georgia
OK, I have an old system that I am trying to bring up to code, let me give you some details. 800 amp 277/480 .Y.at the switch gear there is of coarse parallel feeds. Three hots and a neutral, there also is ground coming from the transformer in both pipes and going to a lug on the switch gear can. Also bonding bushings at this point and the other panels that are high voltage. I have not located a ground rod as of yet. There is a 4 /0 coming off the neutral bar and bonding the cold water pipe. I know back when this was put in you guys used the pipe for your ground. This has me throwed off just a little. There is no main bonding jumper in the switch gear. Why. Can some one please explain why its done this way. And what do I need to do to bring it up to code. With the grounds coming through with the feeder pipes, is it supposed to be separate at the switch gear. And if so this is the first point of power, before the switch gear is the transformer and meter. Why the the cold water pipe bond coming off the neutral bar. Also the transformer is stepping voltage down to 120/208 .how do I bond and ground on this past the transformer. Thanks
Sent from my SM-S367VL using Tapatalk
