Bonding and Grounding
There is three Engine with skid mounted with welding on one long skid so did the each skid has to be ground
Your picture isn’t displaying, and your question isn’t clear. Can you try to describe the situation and question again?
It sounds like you have three skid-mounted units that are then mounted in one larger skid. If so, a single bonding connection should be sufficient.
If there is electrical equipment, the bonding is done through the supply circuits EGC. Grounding as in ground rods is not recommended.
