When you install a sub-panel in a seperate building, you keep the neutral and ground bars seperate, right?
It was fed from a main panel with USE cable with innerduct. In a GE 100A residential panel I should be able to remove the buss bar between the two, correct.
Then just bond the ground bar to the tub and to a ground rod?
Do you know the code ref.? (250.32)?
Thanks for you input.
Joe
Joe
