Hi from Texas! If I run a paralleled metal raceways from a service disconnect to a panelboard or from the meter base to a service disconnect or panel, do I have to install bonding bushings at all 4 ends. 250.92(A) says that all service equipment non-carring metal parts (nipples) must be effectively bonded toghther.
A friend in the trade says that only one raceway should do, and if I do the knock with a "knock out set" I don't have to install bonding bushings,
is that what 250.92(B) means, Reading the code book creates more questions than answers, I need someone to translate!
