ramsy
Roger Ruhle dba NoFixNoPay
- LA basin, CA
- Service Electrician 2020 NEC
Since a bonding bushing stops like a threaded bottle cap, inside the box, the outside connector rubber is sloppy, not tightly sealed to the outside of the box.
Therefore, a tapered locknut is used as a spacer to close the thread gap, which tightens the seal against the box.
The question is which side of the box to put the old locknut / spacer.
Electrical guy says bonding bushing should not have the old locknut behind it, since it's not intended or listed for use with another locknut behind it.
In all cases the bonding bushing is inside the box, as it should be. However, when the added locknut is outside the box, the rubber seals better, since the locknut prevents it from folding over backwards during tightening.
Both foreman also agree inspectors could red tag the locknut for being on the outside of the box, regarless of its critical use as a spacer and seal protector.
Mechanical guy points out, when combined together inside the box, the first locknut digs into the box paint and bonds better, since the smooth-backed, bonding bushing cannot. No debate there either.
Are bonding bushings listed for use with locknuts?
Are locknuts listed for use outside of a box?
