Hi,
I have a couple of questions regarding bonding/grounding.
1) The sketch below leads you to believe that the bonding jumper has to be a separate wire, is this the case or can you attach the grounding conductor to the bushing and then into the conduit?
Here's an example I saw walking one of the houses we built. The grounding conductor attaches to the bonding conector at the end of the emt and then connects to the incoming water service.
2) If you connect your meter base to the service panel with rigid conduit does it need to be bonded on both sides (meter base and service panel)?
Thanks
Thanks
