Re: Bonding DIN Rail
"DIN rail" is a slang term for the mouning track commonly used with terminal blocks and other snap-on mounted devices in control panels.
 A better description is 35mm DIN rail, for the most common style that looks like an upside down top hat.
 There are actually three types of mounting rail:
 DIN 1 - 15mm wide, symmetrical - looks like the old style terminal block mounting strips.
 DIN 2 - 32mm wide, asymmetrical - looks like the letter G
 DIN 3 - 35mm wide, symmetrical - 7.5mm deep is the most common size although many larger devices need the 15mm depth instead.
 DIN rail also comes plated, galvanized, or bare in steel or aluminum and with or without prepunched mounting holes. The most common length is 2m for steel and 1m for aluminum. Some distributors even stock it in 3 and 6" precut lengths.
