OK, let's say you come off your main panel in your house to feed a load-center out in your shed. The load-center will be 120 volts, so of course will only accommodate single-pole breakers. Let's say I run 2C/with grd UF cable to this loadcenter. The load-center only has one ground-bar in it. So, of course I wire the black wire from this UF cable to the hot lug in the load-center, but in light of not bonding the neutral(grounded conductor) and the EGC in sub-panels, what do I do with the white wire (neutral) and the bare wire (EGC), what with there only being one ground-bar in this load-center?
