bmarkie
- South Carolina
- retired homeowner/electrician
I am a retired disabled electrician/homeowner. Recently I had my water heater replaced with a electric replacing gas and had a professional electrician do the job since I am no longer able to stand for any length of time.
The electrician ran a 30 amp circuit with #10 wires a distance of 12 feet. So there is a lot of people calling for the hot and cold pipes to be bonded but since it is not requires where I live most dont do it.
In my situation I have pex all over. There a #10 solid copper wire from panel from the panel to two ground rods at the side of the house and one grounded on the gas pipe.
From the water heater 3/4" copper pipes go up 18" and then transition to pex. There is no need to bond the pipes but just for my peace of mind and since I dont think it would cause any problems, I was thinking of running a #10 solid ground wire from the hot and cold pipes to the ground rods.
Any thoughts would be greatly appreciated.
Thanks,
Thanks,
