Bonding emt for low voltage
Jesse7623
eastern Mass
I have a situation where the low voltage guy on my job has 2- 1" emt pipes terminated in a 4-square box to protect his speaker wires.The pipes are about 6' long and the other end is in the drop ceiling in the floor below no box on that side just male adapters with bushings.
My question is;I am required to ground these pipes,right?And if so what is the most convenient way?
thanks in advance,
learn something new everyday
thanks,
I guess I was a little confused about the bonding issue but its not even necessary.Yeah!!!:grin::grin::grin::grin:
If you are on a spec job the specs might require them to be.
A lot of lan jobs that I have had specs for have required every pipe that they are using to be bonded regardless of length and size.
