I was wondering if have to treat a transformer as a service and bond the conduit to it with bonding bushings? Transformer is 120/208 with a 480 primary being fed from a distribution panel.
If you have rigid 90's stubbbing up through your floor that are being fed from PVC runs do you need bonding bushings on the conduits connecting to the panel?
If you do need to bond in either of these cases can you run a jumper from your bonding bushing to the can or do you have to loop your EGC through the bushing?
Appreciate the help!
