powerplay
- In front of a computer.
An Auto Lube Shop has several Gas Meters attached to it which feed their Building and also goes from the Load side of two Meters, under the pavement to another Building across the lot. The Gas Lines are stubbed up at the other building with shutoff valves which then enter the Building with Rigid Pipe. Inside the building they are connected to copper line where they run up to Rooftop Units. I can't see where they would have bonded the Gas Line to Ground, but if the lines go through the ground, is there a problem with bonding the lines where they enter the Building?? ...I know the Gas Company does not want their pipes on the supply side of the meter to be Bonded... would the same issue arise under the circumstances the second Building is set up??
