250.104(B) Other Metal Piping. Where installed in or attached to a building or structure, metal piping system(s), including gas piping, that may become energized shall be bonded to the service equipment enclosure, the grounded conductor at the service, the grounding electrode conductor where of sufficient size, or to the one or more grounding electrodes used. The bonding jumper(s) shall be sized in accordance with 250.122 using the rating of the circuit that may energize the piping system(s). The equipment grounding conductor for the circuit that may energize the piping shall be permitted to serve as the bonding means. The points of attachment of the bonding jumper(s) shall be accessible.
And what is your concern?Originally posted by problemsolver600:
I had to move an exisiting service in a Cook Co. community, and was required to upgrade the ground to 4 guage, install the bonding jumper at the water meter, install a grounding rod ouside, and GROUND THE HOT WATER, COLD WATER, AND GAS PIPE AT THE WATER HEATER, PER CODE.
I still have the inspector's notes in my files.
