National Electric
New member
I have two situations that don't fall in the norm. First, I have a large generator (Semi size) and need to supply a MDP that exists at the site. There is no utility power. With this said no transfer switch is needed. Can I just ground the Generator to an electrode; run a 4 wire to the MDP that is already bonded? Would the Gen feed be the same as power Co. (4 wire)
Question two: Same situation (no utility power up here) this time I need two Gens. (Only run one at a time) I have a 4 pole transfer switch. The MDP is existing and bonded. Should I only ground the gens, run 4 wire to transfer switch and out of transfer switch to MDP? Again isn't the feed like the utility?
