123ozzie
- chicago illinois
I have an unusual situation I need help with. There is a utility transformer that feeds a bank of meters. Each meter has its own disconnect. The way I understand it, this is my "service disconnect". A building about 75 feet away, is fed from the meter bank with three hots and a ground. No neutral. The feed from the meter goes to a 200 amp 480 v panel. Someone noticed there was not a cold water/building steel ground inside the panel. Should I pull a #4 (based on 250.66) from the water service, through the panel, then 75' to the meter and bond it on the neutral? Should I pull a neutral from the meter into the 200 amp panel and bond the cold water GEC there? Please keep in mind the neutral bus in the bank of meters feeds other unattached buildings. Any help with code references would be greatly appreciated. Thanks
