Coppersmith
- Tampa, FL, USA
- Electrical Contractor
I'm running about 30 feet of rigid conduit underground. Both ends turn up out of the ground and transition to PVC, i.e. the rigid is not bonded to any other part of the system. I think I'm required to bond it. One end is a few inches away from a ground rod. Is it compliant if I put an exterior clamp on the pipe and bond it to the ground rod? The ground rod is a supplemental for a subpanel. The conduit is carrying the feeder for that same subpanel.
