Grouch
- New York, NY
Hi all,
This is regarding section 250.148: "Continuity and attachment of EGCs to boxes"
Part (C) of this section, you tie (using a wirenut) the EGC's together and connect them to the grounding screw on the metal box... that bonding jumper from the wirenut to the grounding screw... is that sized based on section 250.102(D)?... which is the equipment bonding jumper on the load side of an overcurrent device?
I don't see 250.148 mentioning the size, so I'm assuming you go back to 250.102(D).
