jmartin6261
- Lexington, KY
Is a bonding jumper required between the XO terminal and ground on a wye secondary transformer if there is no neutral conductor installed in the secondary feeder?
Installation consists of a 460 delta ~ 460Y/265 volt, 3 phase isolation transformer with electrostatic shield feeding a variable speed drive on an extruder. There is no neutral conductor installed to the extruder as it does not require one.
If it is not required, wouldn't it be advisable to install for clearing of ground faults?
