bonding jumper verification
69gp
MA
Bonding jumper size verification.
Project consist of the following. 24" wide by 300' long aluminum cable tray, 12 DC circuits protected by a 225 amp breakers. Largest conductor is a 300 MCM aluminum cable. There are several expansion joints in the cable tray. There is a grounding conductor that is run with each cable set that is a #1 Aluminum cable. This only hits the end of each cable run.
I come up with a #4 copper conductor for bonding the cable tray at the expansion fittings. does this seem correct?
thanks
