Brandon Loyd
I have an MCC section with a xfmr and panel inside. The xfmr has a bonding jumper/grouding electrode attached to the MCC ground bus, which has a ufer or building steel ground itself. The panel above that the xfmr feeds has a bonding jumper from its ground bus bar to its neutral bus bar. The panel ground bus also has a ground to the MCC ground bus. I have heard it is ok to install your bonding jumper either in the xfmr or in the first panel. But is it ok to have both? Is the MCC's ground bus a suitable grounding electrode for the neutral return path? Or should it always have its own seperate path?
