X xara Member Location minneapolis, mn Apr 6, 2016 #1 Where is the supply side bonding jumper and where is the main bonding jumper in the panel? And what two things does each connect? Last edited: Apr 6, 2016
G ggunn PE (Electrical), NABCEP certified Location Austin, TX, USA Occupation Consulting Electrical Engineer - Photovoltaic Systems Apr 6, 2016 #2 xara said: Where is the supply side bonding jumper and where is the main bonding jumper in the panel? And what two things does each connect? Click to expand... What test are you prepping for? Or maybe I should ask what test it is that you are trying to get us to prep you for.
ActionDave Chief Moderator Staff member Location Durango, CO, 10 h 20 min from the winged horses. Occupation Licensed Electrician Apr 6, 2016 #3 xara said: Where is the supply side bonding jumper and where is the main bonding jumper in the panel? And what two things does each connect? Click to expand... Simple answer is the main bonding jumper is at the first disconnect of the service. SSBJ is for a transformer and can be in the first disconnect or the transformer. Look at 250.24 and 250.30. The handbook has some good illustrations.
