SmithAndrewR
- Franklin, CT, USA (Afghanistan)
At this point it is clear the code allows you to splice in conduit bodies if they are marked by the manufacturer with their volume. My question is for metalic conduit bodies. Once you make a splice in one doesn't atricle 250.148 (c) which requires a connection by grounding device between the box and EGC's come into play? I have not seen a conduit body with provisions for a ground screw and am not sure how to meet this requirement.
