moab88
- West Virginia
- Journeyman Electrician
My APCO doesn't allow equipment ground to pass through or connect in meter base. I have dual meter base (linked below) coming out of each side I'll have 200 Amp disconnects feeding 2 separate 200 A panels for duplex. If the neutral lugs in meter base are bonded to case I shouldn't need the equipment ground lug also. If neutral lug isn't grounded how am I supposed to bond neutral without making any ground connection within the base? This is an AEP approved meter base also.
