bonding monitoring system
don_resqcapt19
Illinois
retired electrician
Is there any type of system that will let me monitor the conductivity of mechanical joints in a pneumatic conveying system? This would be used to prove that all joints are conductive enough to prevent the build up of static charges as the plastic resin is transported through the system. The system has at least 1000 joints.
Don
Re: bonding monitoring system
Some ground check systems used in drag line and mining applications circulate a milliamp current through the ground wire and alarm or trip if continuity is lost. One of these might be retrofitted to your application.
But any monitoring system would probably need a completed isolated pipe. That may be more of a safety issue than a loose coupling.
Any system trying to monitor the joints would essentially be a big ohmmeter with leads connected at each end of the pipe. But the meter will also read the resistance of sneak circuits caused by the pipe touching the grounded pipe rack or building steel or by metallic objects in the pipe connected to grounded systems like control valves, thermocouples or pressure switches. The sneak circuits could mask a bad coupling joint.
Isolating the piping so the only current path is through the pipe could be a lot of work for little benefit. The pipe would probably have to be isolated at every pipe support.
The cost of isolating the pipe to allow accurate monitoring is probably more than the cost of installing small bonding jumpers on every coupling and grounding the heck out of the piping run to drain off any static charge.
Good luck solving an interesting problem.
Bob,
Actually they are asking about doing both. Their standards require a periodic check of the bonding at each joint. I think that the cost of any system that would monitor each joint would pay for many periodic inspections.
Don
