I am about to estimate a job and have a bonding question.
The existing service consists of a 400 amp meter can with extra lugs for serving multiple panels. Currently, there are two panels served from the meter can (A 200 amp and a 100 amp panel, both interior) The meter can is directly behind the two interior panels, separated only by a 2x4 wall. I will be installing a 200 amp panel (exterior), which will serve the existing 100 amp panel and a new outbuilding. The grounding electrode conductors from the water main and ground rod enter the existing 200 amp panel.
My plan is to install a main bonding jumper from this existing panel to my new exterior load center. (The existing 100 amp is bonded to the existing 200 amp panel.) My interpretation is that this is one central service with multiple enclosures. Does anyone have any thoughts on this?
