I have an existing 100 amp main breaker panel thats being used as a sub panel. The existing installer broke a bonding tab between the two neutral/ grounding bars on each side of the panel and used one side for the neutrals and one side for the grounding conductors.
However when they did this the choose to land the neutrals on the side that had about half the terminals as the grounding side. And I need to land four more neutral wires for new circuits.
My plan is to remove the grounding conductors off the terminal bar and install a separate grounding bar and bond it to the panel. Next I want to bond the neutral bar to the other terminal bar where the grounding conductors were once landed so I can get more spaces to land my neutrals. My thought was just to run a number 4 between the terminal bars and bond the that way. Anyone see a problem with this?:blink:
