Bonding neutral to ground in TT system
gatenzo
New User
To my remote countryside house in Europe comes two overhead wires. Transformator is about 1 kilometer away. Inside a house there is a meter and multiple russian type fuses/breakers(image). There are no ground rods or any equipment grounding conductor installed. To make system safer I installed new distribution panel with RCDs and MCBs downstream the meter and fuses. I'm also replacing wiring from 2 core to 3 core cable installation so I would have equipment grounding conductor. I came up with these questions and can't find answer to it:
Is it wrong to bond neutral to ground in this system without any ground rods installed? Doesn't that make system safe in case of fault so current will have a path to return? What if I put a few ground rods but keep the bonding, will that make any sense?
I would appreciate if someone explains where I'm wrong.
I am closing this thread, in accordance with the [url="https://forums.mikeholt.com/threads/read-before-posting-forum-rules-treatment-of-new-members. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
