I am about to change out a fairly new panel that has been damaged by water.
The service is residential 120/240 200a.
The service is fed underground to a 18x18x10 metal terminal box (mounted on the basement wall).
From there the service condutors go to the meter enclosure via a 2" PVC conduit.
After the meter enclosure the conductors then go to the panel via a 2" RMC nipple.
The panel side of this nipple has a bonding bushing with a #4 to the ground bar.
The main breaker is in this panel and everything else is up to par.
My question is as follows:
The terminal box,should I bond this to the service?
The PVC breaks the path of ground to the meter socket.
Opinions?
thanks in advance
Opinions?
thanks in advance
