Solar_ice_caps
- Florida
- Solar EPC
Just had a preliminary inspection for a solar install and a fail regarding lack of bonding for EMT.
Conduit path in question is as follows:
MSP >> Buried PVC >> Detached Garage Sub-panel (Metallic) >> EMT >> 60A Disconnect (Metallic) >> EMT >> PV Combiner (Non-Metallic) >> EMT/Flex >> PV Array JB (Non-metallic)
Circuit is 120/240 and has a green EGC through this entire path.
Inspector said I needed to bond both the (Garage Sub-panel (Metallic) >> EMT >> 60A Disconnect (Metallic)) AND (60A Disconnect (Metallic) >> EMT >> PV Combiner (Non-Metallic)) runs of EMT because they all us concentric KO's. Basically saying that the 60A disconnect (which is itself bonded to the EGC) is insufficient to path the connected emt through the concentric KOs.
My understanding is that because it's <250V and non-service, the connection at the garage subpanel alone would be sufficient even with concentric KOs.
Also said I need to bond the EMT between the non-metallic PV combiner and the non-metallic jbox on the roof. I think that one is valid. It's more previous only I'm unsure about.
Any insight would be great! We are on NEC 2017.
