brantdavid
When connecting conduits to a generator set we always use short lengths (2 to 3 ft) of either flexible metal conduit or liquidtight flexible metal conduit at the generator set for vibration. Conduit sizes go up to 4 inch. For the generator output conduits we always install an ACEG conductor in each conduit.
The flexible conduit is not a listed grounding path in this application. Is it worth the additional cost to install fittings with a grounding lug on each end of the flexible conduit and then install an external bonding jumper around the flexible conduit?
The generator set voltage could be 120/240V,1 ph,4w; 120/208V,3ph,4w or 277/480V 3ph, 4w.
I would greatly appreciate any comments or recommendations on this.
Sincerely,
Dave Brant
Sincerely,
Dave Brant
