Natfuelbilll
Job I'm on has grounding electrode conductor conduit (sleeve?) 30" below grade and extending 24" above grade to where the grounding electrode conductor is terminated onto structural steel. Does this conduit need to be bonded to the grounding electrode conductor? If so, is the bonding jumper required to be the same size as the grounding electrode conductor per 2014 250.64 (E)(1) and (3)?
Thanks guys!
Thanks guys!
