timm333
- Minneapolis, MN
- Electrical Design Engineer
I have a question about the bonding of metallic armor of cables as per NEC. For armored power cables: we connect the armor to the “main” ground on both ends of cable . For armored signal cables: we connect the shield wire to the “isolated” ground at only one end of cable.
For armored signal cables: should the armor be connected to the “isolated” ground or to the “main” ground? Also for armored signal cables: should the armor be connected to ground at one end of cable or at both ends? Thanks
