Hello everyone, this is my first post here. I am in NJ and completed a whole house rough and finish. I have a 325Amp meter socket with a Square D 150Amp disconnect to either side. The main to the meter socket is 300 MCM Aluminum in 2.5” pvc conduit. The feeders to the disconnects are 4/0 Aluminum. Each disconnect feeds a 40 circuit 150 Amp Square D panel. Panels are located next to each other in Basement 42 feet from disconnects on outside of house. They are connected with 4/0 Aluminum XHHW. My confusion is bonding of everything. I currently have #2 Copper THHN running from Gas pipe to one side of water meter to other side of water meter to 150A subpanel 1 ground bar to 150 subpanel 2 ground bar to disconnect 1 to disconnect 2 to meter socket ground to 5/8” 8’ ground rod 1 to 5/8” 8’ ground rod2. Ground rods located 6’ apart. No bonding screws in subpanels or disconnects. My question is; is my setup correct? Thank you ahead for any responses.
