ceb58
- Raeford, NC
On a building I am doing it will have a sprinkler system installed. I have 2 driven rods and the building steel is bonded. Is the sprinkler riser requried to be bonded? The reason I ask is this from an old thred.
From NFPA 13, 1999:
5-14.4.3.5: In no case shall the pipe be used for grounding of electrical systems.
The use of sprinkler or underground piping for electrical grounding increases the potential for stray currents and increased galvanic corrosion. In addition, the use of nonconductive joints may not provide the expected ground. Electric equipment should be grounded in accordance with NFPA 70; National Elecctrical Code.
(Automatic Sprinkler Systems Handbook)
