Al Pike
- Honesdale, Pa
Do the pool's slide anchor studs need to be bonded and how if they are installed after the deck is poured? I thought about building a template out of rebar for encasement but Im unsure if this is overkill.The slide instructions show anchors installed with epoxy and studs that will be exposed in the base of the slide which is all bolted together plastic.These are the only parts not connected to the grid.
Thank's
Thank's
