Re: bonding propane line
I had a similarly-bizarre chain of events cause the EGC of an entire circuit to become energized a couple of years ago. It took me about 20 minutes to discover the cause, which was probably as old as the house.
The then-undersized grounding conductors in a two-gang switch box had not been capped; typical practice back then. The EGC of the incoming home-run happened to be nicked when it was stripped, and broke sometime later.
The twisted bare wires happened to be pointed upward, and the broken EGC slowly screwed itself down the spiral like a nut on a bolt, probably from household vibrations, until it came into contact witha hot screw on one of the switches.
This was discovered the usual hard way: by shocks received when using the bathroom light switch, as the fingers swept over the plate-screw heads. The metal box energized the switch straps, which in turn energized the screws.
Fortunately, there was enough slack in the cable to expose just enough of the broken EGC to extend it with a small wire-nut, and reconnect it to the original joint, which I, of course, remade with a second wire-nut.
The homeowner declined my suggestion doing this repair to the rest of the house. "I'll call you back if it happens again." I'll be here.
