Bonding questions?
maloo
Marion, Iowa
The NEC requires and intersystem bonding terminal per 250.94. Can I use that terminal bar to run a #6 to the gas meter to comply with CSST requirments for bonding or is it required to be a seperate wire?
Second, can I tap the #6 to the water meter to go to bond to the gas meter? The water line coming in is copper so it is more of a grounding electrode then a bonding point if my understaning is correct.
Third question is if I run a #6 to a phone board for a bussines in emt is it required to be bonded on both ends of the pipe same as if it was a GEC?
In advance thanks for any input.
