electricalperson
- massachusetts
am i required to install a bonding bushing at both ends of a metallic raceway that contains a grounding electrode conductor that starts from a main panel with no concentric knockouts. also should the bonding jumper be the same size as the GEC? example one inch EMT containing a 1/0 thhn GEC.
also another question. are bonding jumpers required in 480volt panels even if the knockouts are not concentric or ecentric? example: half inch emt carrying a few circuits feeding light switches. another example 12/2 MC leaving a panel feeding a 480v load.
im pretty sure the code requires bonding on those examples i stated above but someone at work says that its not required. i dont have a code book handy.
