Willie Pete
:-?Where is it required by code to bond the rebar in a residential footing?
It's as iwire has pointed out with the possible exception being if you're still on the 2002 NEC the wording at 250.50 says "if available" which is a lot different than the '05 which says "where present".:smile::-?Where is it required by code to bond the rebar in a residential footing?
Check out the sections that Bob posted. Chances are very good that you'll need a CEE in any new building even a residential dwelling.
Is there typically rebar in resi foundations in your area?
There never seems to be any on the houses I wire. I always try to get #4 in there anyway to avoid ground rods.
