Bonding security fences
jim dungar
Wisconsin
PE (Retired) - Power Systems
This is not about bonding fences around open air substations/switch yards.
I have an outdoor 34.5kV metal-enclosed fusible switch lineup. The equipment sits on a concrete pad and is surrounded by stone, river rock not gravel. There is a ground ring installed under the stone around the gear and pad, the metal-enclosed gear is bonded to this ring. There is a chain link fence surrounding this equipment yard which comes within 3ft on the sides, 5ft on the rear and 10' in front. The fence has a man gate and a double door vehicle gate.
In the old days, a bonding jumper from one fence post to the ground ring was considered sufficient for bonding. I am not completely comfortable with the simple method.
I think there should be bonding at each corner post, with jumpers across the gates. I do not think a perimeter ground ring would be required at the fence line.
Does anyone have any comments or resources?
Soares does not address bonding chain link fences and IEEE-80 is vague on actual details.
jim dungar
Wisconsin
Check with your local POCO & see how they do it.
This is not for a utility switch yard or substation, there are no open conductors, there is no barbed wire. This is no a situation where step potential is an issue.
NEC 250.190 requires the fence to be grounded. How do people 'ground' chain link?
The requirements in IEEE-80 and the 'Design Guide for Rural Substations' seem overkill. Effectively they want a connection to the ground grid conductor every 75', this fenced area is only about 30' long.
don_resqcapt19
Illinois
retired electrician
The last one I did was for 5kv to 480 volt sub with no exposed live parts. The job specs required a connection to the posts on each side of the gates, then every other post and a flexible jumper to the gates. It did not require any direct connection to the chain link fabric itself. I am sure that was very much overkill.
jim dungar
Wisconsin
Thanks, I was pretty sure that simply bonding each fence corner post and across the gate, was not too extreme.
Hv&Lv
Engineer/Technician
We connect directly to the chainlink at every other post. It only takes 6 more inches of wire and a crimp connector.(nonreversible) Of course, we use the specs you mentioned.
To answer your question,
Crimp connector.
I agree, it seems like overkill since the chain link you ground to is weaved in and the continuity depends on how tight the fence is.
jim dungar
Wisconsin
For open air yards i require a ground conductor to be woven all the way up to the barbed wire.
But this is simply a security fence, which i probably would have ignored except it is within 'touching' distance (<5') of the equipment enclosure.
