Bonding Separate Services feeding a Common building.
Colorado
NEC 250.28- Each service-disconnect shall have a main bonding jumper.
NEC 250.58- Where separate services supply a building and are required to be connected to a grounding electrode, the same grounding electrode shall be used.
I am working on an industrial project, where 2-services provide power for one structure. The (2)transformers and (2)Main disconnects are approximatly 400LF from the distribution boards with-in the structure. Equipment grounding conductors have been installed with each feeder.
I am pretty sure I need to provide 1-grounding electrode system at the structure and bond only the equipment grounding bus from each distribution board to the electrode.(NO neutral-to-ground bonds.)
I know I have to provide main bonding jumpers in each main disconnect(neutral-to-ground connection), however I am totally lost as to weather to provide (2) separate grounding electrode systems at the main-disconnects(One for each system) or if I need to provide (1)grounding electode and bond both systems to it?
My gut says that if I combine the systems at the main disconnects I am creating "objectional current" paths with-in the system. Can anyone point me in the right direction?
Re: Bonding Separate Services feeding a Common building.
The more I look at it, "objectional" current flow is not an issue.
By providing one electrode at the service disconnect it appears multiple return ground fault paths are created. This allows a fault in one system to return through the other to get back to it's source. Is this a problem? Don't we want the fault to get back to the source by any means, so the appropriate power can be provided to open the overcurrent protective device?
Art. 250.58 Where seperate services supply one building and are required to to be connected to a grounding electrode, the same grounding electrode shall be used. Two or more grounding electrodes that are effectively bonded together shall be considered as a single grounding electrode system in this sense.
