Reference NFPA 70, 2008 handbook, Exhibit 250.15, page 214. For wood construction, if there was a restroom on the upper floor (in the area served by the separately derived system) there would be a requirement to bond the water pipe to the grounding electrode conductor, per 250.104(D)(1).
If the building were of steel construction, then the separately derived system could be connected to the building steel in the immediate area with restroom water pipe bonded to the building steel in the restroom area.
Correct?
Correct?
