Re: bonding the well
If this is the type of well cap that I'm picturing (has a threaded hump on the edge onto which you terminate the conduit), bonding to it is an exteremely good idea. I've seen many instances where the well pump wire, where it bends down over the edge of the cap's ring to go down into the well, gets a scuff mark in it and energizes the well casing. With metal well casing, this often trips the breaker. With PVC well casing, all you have it a hot well cap. Just my opinion, based on nothing but stuff I've seen happen.
