Bonding to end use equipment- 501.30(A)
greenspark1
New England
I am trying to envision how to use a bonding jumper on both end of the conduit. The panel/source end makes sense and is straightforward. But how do you use a bonding bushing/jumper at a light, control equipment, or similar? I typically run rigid to close to the device, then transition to flex and a sealing fitting. If I stick a bonding bushing on the end of the flex, what do I run the bonding jumper to? This seems awkward. Thanks for any ideas.
