Several of the buildings we are wiring have gas services run to them. The water heaters and fireplaces are the only equipment used for the gas. Our AHJ is requiring us to run a #10 from where each gas service enters the building to the closest subpanel in the building. Some of the buildings have up to 3 points of entry with the gas. So we have been taking 3 separate jumpers to the closest panel. Does this seem logical for a requirement? Also can anyone explain to me using the equipment grounding conductor of the circuit that may energize the piping system is done. Do you take a jumper from the gas pipe to the outlet supplying the equipment? In some of the buildings we have 12 separate units. Would bonding be required at each fireplace or at just on per gas service?
Thanks, Tom
Thanks, Tom
