Vaughn75
- Connecticut
- Electrical Contractor
If you install a GFCI plug in a box that has conductors that are BX cable and no ground wire. If you use a ground rail from the box to the GFCI and effectively use the metal jacket of the BX as an EGC. Is that code compliant or do you have to put the sticker on the face plate saying “no equipment ground”.
