Here's what i got.
Duplex; Main disconnect outside, our main panels become subs.
Plastic pipe coming in, the entire house plumbed in plastic except, copper to the H2O meter, t's off into each unit where there's a copper manifold. Also they convert over to copper under the sinks and the outside spichots Approx. 1' of copper.
I ran a bond wire from one of the subs to the first available copper line. DONE!
Co-worker wanted to know why i didn't run a second bond wire from the other panbel. I told him the copper was already bonded in the other unit, and by bonding it again we would create a parallel path.
Can you have a parallel path with your bonding wire, what harm would it cause?
At what point are we required to bond the copper?
It's not practical to bond under every sink, toilet, and faucet in the house. How big does the manifold need to be, before we bond it?
A friend was in a a similar situiation and was required to run a solid #8 to each faucet, sink, toilet etc. That's rediculous!!!!!!
How likely is it for a 12" piece of pipe, to become energized under a toilet. You might as well bond the shower curtain rod.
