BONDING
jaydagner
A non-metallic 4x4 box with a metal p-ring attached, is the p-ring required to be bonded?
NM Cable is the wire type.
Re: BONDING
My gut instinct tells me yes. However, a code rule to back up my answer escapes me at the moment.
Nonetheless, I never see it done.
If we can ground a switch in a metal box with the device screws, I don't see any hazard in the reverse to ground a plaster ring.
But, the code is code and we must follow it no matter what we think is OK.
[ January 11, 2005, 04:16 PM: Message edited by: peter d ]
Re: BONDING
does it have a way to bond it?
you are talking about the plaster rings that extend above a handy box - right?
I am not sure you are allowed to install them on a plastic box.
Re: BONDING
Good point Bob. I hadn't even thought of that. :eek:
I have seen metal rings that don't even cover the opening of the plastic box.
I think your only code compliant solution is to use a plastic ring.
Re: BONDING
I'm at least thinking "Yukkk".
I agree with Bob. And don't they have to be identified for use or listed or something? I've never seen a plastic box with a screw pattern for a ring.
This is 4 square or 4 11?
Re: BONDING
250.4(A) ... (3) Bonding of Electrical Equipment. Non?current-carrying conductive materials enclosing electrical conductors or equipment, or forming part of such equipment, shall be connected together and to the electrical supply source in a manner that establishes an effective ground-fault current path.
